ZKL extends the range of special bearings for rolling mills
ZKL rolling mill bearing
ZKL noticeably extends the range for special applications in rolling mills by implementation of four-row cylindrical roller bearings in its production program. Bearings PLC 512-72 were developed and produced on request of a major Czech company in the field of rolling mills. Newly ZKL will supply to this customer a set of specific bearings. This delivery is the start for long-term cooperation in segment of large-size and special bearings with another important Czech partner.
source: ZKL Group
