Triangle Manufacturing Introduces Stainless Steel Aluminum Lazy Susan Bearings for Marine and Medical Applications
Triangle Manufacturing’s standard lazy susan ball bearings are now available in aluminum with stainless steel balls. The standard material for their lazy susan bearing is galvanized steel with carbon steel balls. However, using aluminum and stainless steel allows for more versatility and flexibility in terms of applications. These new turntable bearings have applications in the medical industry, in sports and recreation and in marine usage. Using a non-corrosive material allows for humidity and dampness without leading to bearing failure.
Aluminum is non-corrosive, low-cost, light and strong, even in frigid temperatures. This makes it a great fit for outdoor usage, such as tennis ball machines, boating or other recreational activities. It’s also utilized in the medical industry for its hygienic washability and rust-resistance.
This custom option is available in 4 and 6 inch sizes and in high volume only.
About Triangle Manufacturing
For almost a century, Oshkosh, Wisconsin’s Triangle Manufacturing Company has used a foundation of experience, paired with technical know-how and advanced automation to be the leader in fully customizable metal fabrication, product innovation and invention. We have introduced and redesigned fresh products that are progressive in their respective industries. Whether you need lazy susan bearings and HVAC components, pillow block mountings and blower bearing brackets or rod ends and direct-drive motor mounts, you can rely on Triangle Manufacturing’s Creative Engineering. For more information, samples or quotes, visit us at http://www.TriangleOshkosh.com.
source: PR Web
