SKF signs SEK one billion supply agreement for new NautilusTM bearing for the wind industry
SKF has signed a three-year supply agreement, worth around SEK one billion for the new generation SKF Nautilus bearing, with a major wind turbine manufacturer. The new multi-megawatt turbine that will utilize the new bearing is intended for both onshore and offshore installations around the world.
Nautilus-Bearing-Solutions
“We are very pleased that our close development cooperation with this leading manufacturer has resulted in this major order. Wind is a relatively new source of energy and it has developed into a significant business for SKF over the past few years. We are in active cooperation with leading companies within the market to develop future technology and this order is proof that our new Nautilus bearing is well accepted in the industry,” says Tom Johnstone, SKF President and CEO.
The new generation SKF Nautilus bearing was launched in April 2012 at the European Wind Energy Conference in Denmark, and is included in the SKF BeyondZero portfolio of customer solutions, which offer significant environmental benefits. Through reduced friction and improved running conditions, the SKF Nautilus bearing contributes to the reduced cost of energy, helping to make wind energy a cost-effective and affordable energy alternative.
Rebecca Janzon, Global Press Manager,
tel: +46 31-337 3880, mobile: +46 727-173880, e-mail: [email protected]
Marita Björk, Head of Investor Relations
tel: +46 31-337 1994, mobile: +46 705-181994, e-mail: [email protected]
SKF is a leading global supplier of bearings, seals, mechatronics, lubrication systems, and services which include technical support, maintenance and reliability services, engineering consulting and training. SKF is represented in more than 130 countries and has 15,000 distributor locations worldwide. Annual sales in 2011 were SEK 66,216 million and the number of employees was 46,039. www.skf.com
source: SKF
