SKF Marine Condition Monitoring Kit provides an easy way to assess machine condition onboard ships
SKF has announced the availability of the SKF Marine Condition Monitoring Kit. This kit includes everything that is needed to carry out reliable, simplified condition monitoring onboard ships and enables ship operators to take a first step towards condition-based maintenance.
“The SKF Marine Condition Monitoring Kit is easy to set up, use and understand and can give early indication of possible problems. It simplifies maintenance and reduces maintenance costs, says Anders Welin, Business Engineer, SKF Marine segment.
SKF condition monitoring kit
With the SKF Marine Condition Monitoring Kit, even a non-trained user may interpret the results of vibration data measurements and locate the source of the fault in the machinery. The marine-specific software with marine typical equipment models is loaded in the SKF Microlog Advisor Pro and is preconfigured to convert the measured data into an easy-to-understand colour-coded result. The kit also includes a comprehensive step by step user guide to simplify the implementation and training of the crew.
The SKF Marine Condition Monitoring Kit is more than a data collector as it has capability to do additional analysis of the machine, based on FFT (Fast Fourier Transform) frequency band analysis, to detect the most likely root cause of the fault, such as unbalance, bearing failures, gear failures, electrical failure in motors, hydraulic and aerodynamic problems.
The SKF Marine Condition Monitoring Kit has been developed specifically for the demanding requirements of the marine industry and tough onboard conditions. It is well suited for use on a wide range of vessels, including container ships, ferries, Ro-Ro ships, fishing vessels, dredging vessels, tug boats and offshore supply vessel.
The SKF Marine Condition Monitoring Kit contains:
SKF Microlog Advisor Pro, a handheld monitoring device
SKF marine library models
Work instructions for setting up and operating the system
Software package, ARM (Analysis and Reporting software) for reporting and trending (optional)
source: SKF
Minimizar los costes de mantenimiento y de tiempo de parada con rodamientos “lubricados de por vida” utilizando el lubricante Krytox® AUT 2E45
Minimizar los costes de mantenimiento y de tiempo de parada con rodamientos “lubricados de por vida” utilizando el lubricante Krytox® AUT 2E45(0)
Demostrado el largo plazo de vida en rodamientos de bolas para motores eléctricos Krytox El lubricante Krytox® AUT 2E45 ha sido probado y demostrado como una solución de lubricación de por vida para rodamientos de bolas en motores eléctricos industriales en una empresa de producción de celulosa y papel, así como en otras industrias con
Descárgue el Informe de Actividad de Diseño de Rodamientos
Descárgue el Informe de Actividad de Diseño de Rodamientos(0)
Descubra quién lo ha descargado, qué han descargado por familia de productos, país, empresa, puesto de trabajo, etc… Haga clic en la imagen para descargar el Informe de Actividad de Diseño de Rodamientos Sus datos técnicos de rodamientos y sus modelos de CAD pueden llegar a ser la herramienta de ventas y marketing más potente.
Nueva versión en español del software para ingeniería mecánica MESYS.
Nueva versión en español del software para ingeniería mecánica MESYS.(0)
El desarrollador suizo de software en ingeniería mecánica MESYS AG se abre ahora al mercado español e iberoamericano facilitando el uso de su programa de diseño de rodamientos y ejes con una versión en español. Basándose en métodos de simulación numérica y ajustándose a los estándares, esta herramienta ofrece desde el cálculo de la vida
BearingStockShop & BearingStocks en profundidad
BearingStockShop & BearingStocks en profundidad(0)
“En BearingStockShop las industrias consumidoras encuentran los rodamientos que necesitan y pueden elegir entre varios presupuestos para abaratar costes” “En BearingStocks los distribuidores acceden a un mercando potencial de clientes casi ilimitado”. Entrevista con sus cofundadores en Pamplona, España   Nos desplazamos hasta Pamplona (España), ciudad mundialmente famosa por las fiestas de San Fermín, sede
