Outotec Approves Bel-Ray Clear Gear Lubricant for Mining Equipment
Clear Gear Lubricant is a Very High Viscosity (VHV) full synthetic fluid gear lubricant designed for use in open gear systems, particularly in rotating equipment such as grinding mills, cement kilns, driers, agglomerators and pelletizers. Clear Gear Lubricant can replace any open gear lubricant, including greases, compounds and residual products.
BelRay grease.pg
Critical capabilities of this OEM-approved Bel-Ray lubricant are prevention of wear, arrest of existing wear trends and reduction/elimination of vibration. Additional benefits include reduction of gear tooth surface temperatures by up to 20 percent and decreased lubricant consumption up to 35 percent.
Suitable for application to gears and pinions via either a centralized spray system or immersion, the Bel-Ray Clear Gear Lubricant offers process plant operators these essential features:
* Low Temperature Fluidity – The unique blend of synthetic hydrocarbons and select ester base-fluids provides excellent low temperature fluidity.
* High Viscosity – These lubricants provide full separation of gear teeth by forming a thick, resilient lubricating film between gear tooth surfaces, eliminating metal-to-metal contact and the resulting wear.
* Reduced Micropitting – Special additives reduce and prevent micropitting, a form of gear tooth damage that occurs early in the life of gears and often the root cause of premature gear failure.
* Clear Lubricating Film – Easy visibility allows the operator to perform inspections without costly machine shutdowns and clean-up.
* Full Fluidity – Promotes easy drainage to waste collection containers and eliminates used lubricant accumulation in the gear tooth roots and shroud.
Bel-Ray Clear Gear Lubricant has also received OEM approval from Metso Minerals of York, Pa., a provider of world-leading technology and services to the mining and construction industries. In addition, this premium lubricant exceeds ANSI/AGMA 9005-E02 Specification Annex D for minimum viscosity recommendations for open gearing in intermittent lubricant applications.
“This OEM approval from Outotec confirms Bel-Ray’s heritage of developing superior application-specific products that help our customers get the most out of their machinery and equipment,” said Don Howard, new product innovation – mining at Bel-Ray. “Receiving this OEM recognition from a company like Outotec is particularly rewarding, given their notable position as a worldwide technology leader in the sustainable processing of the earth’s resources.”
source: Azom.com
Minimizar los costes de mantenimiento y de tiempo de parada con rodamientos “lubricados de por vida” utilizando el lubricante Krytox® AUT 2E45
Minimizar los costes de mantenimiento y de tiempo de parada con rodamientos “lubricados de por vida” utilizando el lubricante Krytox® AUT 2E45(0)
Demostrado el largo plazo de vida en rodamientos de bolas para motores eléctricos Krytox El lubricante Krytox® AUT 2E45 ha sido probado y demostrado como una solución de lubricación de por vida para rodamientos de bolas en motores eléctricos industriales en una empresa de producción de celulosa y papel, así como en otras industrias con
Descárgue el Informe de Actividad de Diseño de Rodamientos
Descárgue el Informe de Actividad de Diseño de Rodamientos(0)
Descubra quién lo ha descargado, qué han descargado por familia de productos, país, empresa, puesto de trabajo, etc… Haga clic en la imagen para descargar el Informe de Actividad de Diseño de Rodamientos Sus datos técnicos de rodamientos y sus modelos de CAD pueden llegar a ser la herramienta de ventas y marketing más potente.
Nueva versión en español del software para ingeniería mecánica MESYS.
Nueva versión en español del software para ingeniería mecánica MESYS.(0)
El desarrollador suizo de software en ingeniería mecánica MESYS AG se abre ahora al mercado español e iberoamericano facilitando el uso de su programa de diseño de rodamientos y ejes con una versión en español. Basándose en métodos de simulación numérica y ajustándose a los estándares, esta herramienta ofrece desde el cálculo de la vida
BearingStockShop & BearingStocks en profundidad
BearingStockShop & BearingStocks en profundidad(0)
“En BearingStockShop las industrias consumidoras encuentran los rodamientos que necesitan y pueden elegir entre varios presupuestos para abaratar costes” “En BearingStocks los distribuidores acceden a un mercando potencial de clientes casi ilimitado”. Entrevista con sus cofundadores en Pamplona, España   Nos desplazamos hasta Pamplona (España), ciudad mundialmente famosa por las fiestas de San Fermín, sede
