Enhanced Performance Offered By Timken Housed Unit Bearings
The Timken Company (NYSE: TKR) is introducing an enhanced line of solid block roller bearing housed units designed for greater reliability and longer bearing life.
Timken® Type E tapered roller bearing (TRB) solid block housed units offer a significant increase in design life over industry-leading designs that utilize standard Timken bearings. In addition, Timken e-coating outperformed standard industry black oxide or powder coatings used on housings and locking collars. Finally, Timken-designed double-lipped seals have outperformed single-lip seal designs from a leading competitor in protecting bearings from debris in harsh environments. Visit www.timken.com/typee for complete testing details.
Timken housing Units
Timken® spherical roller bearing (SRB) solid block housed units are constructed of solid steel with the ability to handle +/- 1.5 degrees of misalignment. The customizable units feature, five locking configurations, six primary sealing options and end cover options, for a bearing solution that meets very specific application demands.
New Clydesdale Colliery, in Mpumalanga, South Africa, recently switched several bearing positions in their conveyor system to Timken SRB solid block housed units. “We were getting eight weeks of bearing life maximum with our previous solution”, said Frans Botha, mechanical foreman at New Clydesdale. “Timken presented their units as a potential solution and we gave them a try. It’s 10 months later, the original units are still running and our maintenance cycles have been reduced significantly.”
The complete line of Timken housed units also includes spherical roller bearing split block housed units and ball bearing housed units. All Timken housed units feature enhanced sealing and bearing designs to provide stronger performance in the harshest environments.
About The Timken Company
The Timken Company (NYSE: TKR; www.timken.com) keeps the world turning with innovative friction management and mechanical power transmission products and services that help machinery perform more efficiently and reliably. With sales of $5.2 billion in 2011 and approximately 21,000 people operating from locations in 30 countries, Timken is Where You Turn® for better performance.
source: Azomining
